RER TOP BEAMS MR2 3SGE ROTREX
Postby MANDALAY on Sun Jan 10, 2010 11:13 pm
Need some advise before i go out and buy my M800,
Ill be running a Supra fuel pump.In the Supra they have a FP computer connected to the ECU . The way it works is the FP gets omly 2.5 volt signal when on idle 1000 rpm and 5 volts when started and over 1000 rpm.
Can the Motec do this and how ? This sucker draws 18 amps so i want it low when not on idle.
Next will the MOTEC AS A STAND ALONE run everything the stock ECU does like AIR CON, VSV etc ?
Many thanks guys
MANDALAY
Re: RER TOP BEAMS MR2 3SGE ROTREX
Postby Wolf_Tm250 on Tue Jan 12, 2010 12:52 am
MANDALAY wrote:Need some advise before i go out and buy my M800,
Sorry?
The fuel pump receive a positive voltage of 2.5 volts OR 5 volts ?
Wolf_Tm
Parma - Italy
Wolf_Tm250
Postby mr2andy on Tue Jan 12, 2010 1:18 am
<I think>The way it works in MR2 3SGTE is that there is a relay switch with two output, one of the two output has a resistor pack install on it.
Depends on the current RPM reading from the ECU, the ECU can switch the relay to go through the circuit with resistor pack hence lower voltage to the pump at low RPM and switch to the circuit without resistor pack and give full voltage to the fuel pump at high RPM.
mr2andy
Postby Wolf_Tm250 on Tue Jan 12, 2010 1:34 am
mr2andy wrote:<I think>The way it works in MR2 3SGTE is that there is a relay switch with two output, one of the two output has a resistor pack install on it.
"I think" that too...
That's why I asked about this very strange thing... ;)
Wolf_Tm
Parma - Italy
Wolf_Tm250
Postby MANDALAY on Wed Feb 17, 2010 11:30 pm
Yes as desciribed above about the resistor pac.
So how can i do the same thing with the Motec ?
Ild prefer not to use the resistors. Can it be done ? How about solid state relays
MANDALAY
Postby IJ. on Thu Feb 18, 2010 6:46 am
Pwm and a SS Relay, you can then do a 2 axis table and have it quiet at idle and ramping up as needed.
I run 2 pumps and do it this way with the 2nd pump only active on boost.
IJ.
Users browsing this forum: Bing [Bot] and 6 guests
