Speed and Dig input opinions.. HELP!
Postby bazeng on Sun Dec 27, 2009 6:21 pm
Hi guys,
I'm just wondering if I can get all these 3 inputs onto the SDL?
We only have 2 Speed inputs and 2 dig inputs. I plan to use wheel speed 1 on a front wheel (wheel speed), and wheel speed 2 on the Tailshaft.
I then have a pulley which I plan to use for picking up RPM.
It is a GT101 sensor reading a pulley off the crank. The only thing is that it is an alloy pulley with holes drilled into it, which were tapped and then 2 magnet screwed in which were then shaved flush. The GT101 sensor is a hall effect sensor. The sensor has 3 wires - 8v, gnd and sensor.
Anyway, my plan is to run the tailshaft and wheelspeed on the speed inputs. Can I use the dig input with the pulley for RPM?
Btw, its a carby motor.
Baz
bazeng
Re: Speed and Dig input opinions.. HELP!
Postby IDP on Mon Dec 28, 2009 3:25 am
Should be no problem at all.
IDP
Postby bazeng on Wed Dec 30, 2009 9:07 am
OK,
I believe the GT101 sensor is ok to run on a DIG input.
The other 2 should be ok on the speed input.
I managed to find some documentation on the sensors.
bazeng
Postby JamieA on Mon Jan 04, 2010 2:58 pm
yeh, that will be fine.
JamieA
Return to ADL3, SDL3 and CDL3
