Mercury CDI coil Question!
Includes MoTeC CDIs, Ignition Expanders
Postby Toffe on Sat Oct 31, 2009 1:16 am
Hi everyone, I have resently bought a new CDI4 ignition system with 4 Mercury coils, and are a bit confused about the ferrit cores you get with them. Is there a difference in the coils performance depending on wich ones I use? There seems to be a big difference in the cores mass or size!
And is this ignition system sensitive regarding wich ignition wires to use?
Should I isolate the wires good to prevent interferance or is this not so important with this system and coils?
Thanks for helping me out! :)
Best Regards: Christopher/ Sweden
Toffe
Re: Mercury CDI coil Question!
Postby Toffe on Sat Dec 05, 2009 12:00 am
Anyone?
Toffe
Postby SprinterTRD on Sun Dec 06, 2009 1:24 pm
Either core will work the same.
Which wires are you talking about? Primary or secondary? You should follow the CDI8 drawing for primary wiring.
SprinterTRD
Postby Toffe on Mon Dec 07, 2009 5:17 am
SprinterTRD wrote:Either core will work the same.
The wires going to the spark plugs! Any special or any ones that isn't recomended?
For the system wiring I followed the sheet supplied with the CDI4 that I bought.
Thanks for helping out.
Best Regards _ Kris
Toffe
Return to Ignition systems
