Injector Battery Comp
Postby mhd on Tue Oct 20, 2009 9:25 pm
Hi every body
Does any one know how to be sure about Injector Battery Comp setup
coz I think my setup not corect
Thank's
M.Olabi
M.Olabi
ProRacing Co.
mhd
Re: Injector Battery Comp
Postby forcefed1981 on Mon Nov 30, 2009 3:43 am
Hi
Run car on idle with multimeter attached to battery and check voltage should be above 13 volts and also check fuel mixture reading.Then disconnect alternator from battery run car on idle again if you can do this with your car,check voltage is lower then before then check fuel mixture stays the same.If not adjust battery comp till fuel mixture is close as you can get it.
forcefed1981
Postby mhd on Thu Dec 03, 2009 5:43 pm
Thank's very much for your help
M.Olabi
ProRacing Co.
mhd
Return to Tuning discussions
