Is it possible to have a fuel pressure sender unit sending pressure information to M400 and if the fuel pressure drop under certain psi, have Motec shut down the engine?
Cheers
mr2andy wrote:Hello,
Cheers
Wolf_Tm250 wrote:mr2andy wrote:Hello,
Cheers
I would use a differential pressure sensor between manifold and fuel pressure, and use it in an Aux Comp Table for fuel cut:
it would be way useful because it'll analyze FP-MAP and find eventually a fuel pressure regulator and fuel pump problem even when FP is more than zero.
mr2andy wrote:Wolf_Tm250 wrote:mr2andy wrote:Hello,
Cheers
I never heard of a differential pressure sensor. How does it work?
Users browsing this forum: Google [Bot] and 69 guests
