SDL and SLM
SDL and SLM
Postby figgie on Fri Jul 18, 2008 7:32 am
Question
is there anyway to implement the features that are in the ADL2 into the SDL software/ for the SLM control or is the SDL harware limited in doing that?
Specifically the flashing on certain conditions. This would help in a street car to use the SLM as an indicator of sorts.
IE
Right turn, left turn and high beam useage ontop of shift light useage and alarms also.
figgie
Re: SDL and SLM
Postby JamieA on Fri Jul 18, 2008 10:28 am
Yep, that makes sense, will put a request in...
In the mean time, you can do it already, it is just a little fiddly.
Basically,
*set up a Timer into a GP time(1 second) channel.
*Make an activate/deactivate condition that turns on each time the above channel is updated
*make the same condition turn on after the output channel is true or .3 of a second (change this to set the on/off time
Set a GP on/off channel as the output channel
Make a condition in the slm setup that says, put this shift light output on when the GP on/off is true.
I just tested that and it works fine. Here is the config.
SLM test.U16
SLM flash config
(234.85 KiB) Downloaded 1614 times
JamieA
Re: SDL and SLM
Postby gring on Thu Aug 14, 2008 2:07 am
Are there plans to update the ADL-1 (original) with the SLM capability?
gring
Re: SDL and SLM
Postby JamieA on Thu Aug 14, 2008 9:40 am
There are currently no plans to update ADL software for SLM use, although you can use one if you wish anyhow, it is just a bit more fiddly. Attached is a document outlining the procedure.
DTN0012 SLM and ADL.pdf
slm
(127.39 KiB) Downloaded 2631 times
JamieA
Re: SDL and SLM
Postby figgie on Wed Nov 04, 2009 10:35 am
Hi MoteC
Thought I would dig this from the grave.
Any status if the SDL is going to support flashing SLM condtions? Most needed would be 4 conditions.....
figgie
Re: SDL and SLM
Postby JamieA on Thu Nov 12, 2009 8:36 am
this has been added into SDl3, but I don't know if it is going to be ported back into SDL...
-Jamie
JamieA
Re: SDL and SLM
Postby figgie on Sun Nov 15, 2009 6:29 pm
JamieA wrote:this has been added into SDl3, but I don't know if it is going to be ported back into SDL...
-Jamie
SDL3?
Cat out of bag, new SDL? :)
figgie
Re: SDL and SLM
Postby JamieA on Mon Nov 16, 2009 8:45 am
yeh, it is the updated SDL model, about to start beta testing. Expect to see it early next year.
JamieA
Re: SDL and SLM
Postby killerbee on Fri Nov 20, 2009 5:02 pm
What are the differences going to be ? Is there an upgrade for the SDL to get it to SDl3 trim ?
killerbee
Re: SDL and SLM
Postby DarrenR on Fri Dec 04, 2009 1:42 pm
Hi Killerbee,
New features include up to 120Mb logging, 2 CAN busses, ethernet PC comms, 3 axis g sensor and some of the software restrictions lifted like ADL3 type SLM setup.
The SDL3 is completly new hardware and processor, the only things that are common from SDL to SDL3 are the case, display and connector, so not much chance of updating.
Cheers,
Darren Reynolds
DarrenR
Return to ADL3, SDL3 and CDL3
