Gen 4 L98 Chev Oil sensor?
Postby IJ. on Wed Nov 18, 2009 6:09 am
Does anyone know the 0>5v range of the stock sender?
0.....4.5v
0.....xxxpsi
I "guessed" at 4.5v/100psi which seems close but I'm trying to not have to crack it loose to do a manual calibration on it if I can avoid it so this info would help me a lot thanks.
IJ.
Re: Gen 4 L98 Chev Oil sensor?
Postby Daniel on Sun Apr 11, 2010 7:11 pm
How did you go with this? I am trying to do the same and would like like info on water temp sender as well.
Danic Performance
Daniel
Postby IJ. on Sun Apr 11, 2010 8:03 pm
0=488
103=4176
Custom PSI 1 decimal place
Temp #2 delco 3300ohm
IJ.
Postby Daniel on Sun Apr 11, 2010 11:37 pm
Could you please give me a bit more information on the calibration table?
Thanks Daniel
Danic Performance
Daniel
Postby IJ. on Mon Apr 12, 2010 12:25 am
Sorry about the brief reply earlier I was heading out, not really sure what other info it is you require?
Those numbers will get you in the ball park as they'll interpolate between 0 and 103psi, you can use "read value" for 0 once it's wired and working.
IJ.
Postby Martin on Mon Apr 12, 2010 3:15 pm
Are your values in millivolts?
Postby IJ. on Mon Apr 12, 2010 5:00 pm
Martin wrote:Are your values in millivolts?
Yes Martin, that's the default for "custom PSI 1 decimal place" ;)
IJ.
