direct fuel injection
Postby ElsmoortelG on Thu Jul 24, 2008 1:28 am
Are there already solutions to manage a direct injection petrol engine with a 100 series ECU ? Like the 2.3 turbo from Mazda. Where the injector has to be activated with 100V.
ElsmoortelG
Re: direct fuel injection
Postby John Reed on Fri Jul 25, 2008 5:30 pm
I think Motec Korea lists a driver box for common rail diesel direct injection, so perhaps a driver box for gasoline direct injection exists or is in the works that is compatible with the current line of Motec ECUs. I am sure the Motec staff could elaborate far more than I can.
John Reed
Motec Sales/Install/Tuning/Support
johnreedracing@gmail.com
John Reed
Postby RossB on Tue Jul 29, 2008 10:40 am
We are working on a solution for direct injection engines, both gasoline and diesel but this will be a dedicated direct injection ECU rather than an addition to the current ECU. Exact details and timescale for release are not available at this stage but the intention is to have something available next year.
RossB
Postby ElsmoortelG on Wed Jul 30, 2008 1:24 am
Will it cover the different systems ? I mean like Bosch, Delphi, Denso and Siemens ?
Mazda had a seperate unit to drive the injectors on the diesel common rail and the petrol direct injection.
The engine ECU gave a ground signal to this unit each time it had to activate an injector. So it looked like an indirect injection ECU. In the meantime they integrated this circuit in the engine ECU and the module was abolished.
Is it possible to use this module with an M100 series ECU ?
Anybody tried it before ?
ElsmoortelG
Postby RossB on Wed Jul 30, 2008 12:20 pm
Yes it will cover the different systems.
If the car has a seperate injector driver it may be possible to use this with a Mx00 ECU. I have not tested one of these units but we have customers using the Denso unit which is similar but high side drive. Do you have any wiring information or part numbers for the driver and the injectors? There may be other limitations with using the M800 with the current software for example if you want to do things like multi pulse, and the minimum injection time will be dependant on the ref/sync mode used.
RossB
Postby ElsmoortelG on Sun Aug 03, 2008 1:59 am
I added the wiring diagram and the explanation how the module works.
This should be able to work with an Mx00 series don't you think ?
L3 turbo injector driver module 3.pdf
Explanation how injector driver module works
(23.98 KiB) Downloaded 2365 times
L3 turbo injector driver module 2.pdf
Wiring diagram - connection injectors with injector driver module
(488.33 KiB) Downloaded 2075 times
L3 turbo injector driver module 1.pdf
Wiring diagram - connection engine ECU with injector driver module
(433.07 KiB) Downloaded 2123 times
ElsmoortelG
Postby RossB on Tue Aug 05, 2008 12:05 pm
Yes this looks like it will work ok. Are you looking at doing an installation on one of these engines? Where are you located?
RossB
Postby Martin on Wed Aug 06, 2008 6:05 am
Hi ElsmoortelG,
Out of what Mazda is this Unit?
Postby ElsmoortelG on Thu Aug 07, 2008 12:59 am
Yes we are studying to install an Mx00 on a 2.3 direct injection turbo.
We are located in Belgium.
We want to use it for a year end project/thesis of a masters degree.
First the data out of the original ECU needs to be logged by a ADL2 and then copied in a Mx00.
If that goes wel the idea is to change the diamentions of the turbo and intercooler and slowly test the potential of the engine.
Can you give me some feedback if you think it is possible to log the injection opening time according to engine speed, the injection timing related to TDC and ignition timing related to TDC.
The module origines from a Mazda6 MPS vin GG82L6* serial no above 600001-
ElsmoortelG
Postby Martin on Thu Aug 07, 2008 3:43 am
I know of 2 Mazda3 Mps`s running as race cars in GroupN. They had endless problems with engine failures (detonation) but only on Cylinder 2 an 3 as far as i know. Im not very familiar with these cars but if you need any specific information ill try and get it for you. Ill be receiving the manual in electronic format soon. (planning to fit Motec Mx00 to the cars in future)
Users browsing this forum: No registered users and 30 guests
