MOTEC SDL with AUTRONIC SM4 1.09
Postby bazeng on Sun Nov 01, 2009 10:31 am
Hi Guys,
I have an AUTRONIC SM4 and will be using a MOTEC SDL to log / monitor the engine.
I have all the wiring diagrams etc and just needed confirmation with the wiring.
I am assuming
AUTRONIC______________|____________________MOTEC
SM4 1.09_______________|____________________SDL
RS232 RX - pin 5 (db9)___|____________________TX/TELEM - pin33
RS232 TX - pin 2 (db9)____|____________________RX - pin 34
Is this correct?
I could only find the AUTRONIC pinouts from the AIM DASH documentation.
The SM4's use a stereo jack loom which converts it out to a db9 connector hence the db9 pinouts.
Thanks in advance.
bazeng
Re: MOTEC SDL with AUTRONIC SM4 1.09
Postby JamieA on Mon Nov 02, 2009 9:17 am
With an Autronic SM4, you need to hook up 2 wires.
You connect the Pin 2 on the Autronic D9 (TX) to pin 34 on the SDL (RX).
You also need to hook up pin 5 (which I believe you will find is Ground, not RX)to Pin 37 (0v)
Not absolutely sure about the 0v, when I last did this, I believe that the SM4 wont transmit without the 0v connected, I don't know why.
Perhaps try just connecting the SM4 Tx to the SDL Rx, and see how that goes. If it doesn't work, hook up the 0v...
-Jamie
JamieA
Postby bazeng on Mon Nov 02, 2009 11:53 am
Thanks Jamie,
I will let you know how it goes.
Btw, it's Barry here with the Galant VR4 (from BJP)
The car is alive!
bazeng
Postby bazeng on Wed Nov 04, 2009 8:19 am
My mistake Jamie.
The AIM install details I have are somewhat corrupt and the text is all over the place.
Pin 5 is actually is the gnd on the SM4 DB9 side, not RX.
So it should be:
RS232 GND - pin 5 (db9)___|___________________GND - Pin 37 (0v)
bazeng
Postby bazeng on Mon Nov 09, 2009 10:21 am
Hi guys,
Just a quick question.
How do I obtain the values from the SM4?
I'm assuming its from the Channel:
DATASTREAMS
OR
ECU - Generated Channels
Now,
DATASTREAMS contains JI587
and
ECU - Generaged Channels contains a bunch more values but doesn't contain (MAP or BOOST)
Where can I obtain all my ECU generated values?
I have already enabled the SM4 input by:
->INPUTS
-> Communications
-> RS232
-> Autronic SM4
Thank you!
bazeng
Postby bazeng on Mon Nov 09, 2009 8:50 pm
Ok,
I connected it up.
I just used the unused channels button to find the required channels.
Seems to be working fine!
Pins 2 & 9 on the DB9 connector are good.
Thanks for the help Jamie
bazeng
Return to ECU to Dash Comms
Users browsing this forum: Bing [Bot] and 0 guests
