How to clear the password of M4
Postby Fueltank-Tai on Wed Nov 04, 2009 3:46 am
Dear Ross:
How to clear the password when locked . Is it send ecu to you (Motec company ) to clear the password? Thank you so much.
Fueltank-Tai
Re: How to clear the password of M4
Postby toby on Fri Nov 06, 2009 2:24 am
You can normally clear the password by downgrading the software version in the ecu then upgrading again. BUT BEWARE - YOU WILL LOOSE THE ORIGINAL MAP AND WILL HAVE TO START MAPPING AND SETUP FROM SCRATCH.
M-Tech - MoTeC Dealer UK
toby
Postby SprinterTRD on Fri Nov 06, 2009 12:56 pm
Its not a good idea to change the software version if there is a password in the ECU.
The best way to get the password removed is to take the ECU back to the person who set it. If this is not possible then you will need to return it to a MoTeC dealer.
SprinterTRD
Postby Fueltank-Tai on Fri Nov 06, 2009 3:46 pm
thanks toby and SprinterTRD.
Fueltank-Tai
Postby bx7 on Tue Nov 10, 2009 10:45 pm
Dear Ross.
I am from Argentina and I have one M4 blocked. It´s possible unblocked without send to Australia, becose it's to difficult send to us for the distance. Thanks
bx7
Postby J&R on Mon Nov 16, 2009 2:45 pm
There are only two ways to correctly clear the password from the Passworded ecu
1. Take it back to the Person that set the password.
2. Send the ecu to your nearest MoTeC dealer.
these are the only two correct ways to clear a password.
J&R
Postby RossB on Fri Nov 27, 2009 10:55 am
J&R is correct, there is no other way around it. If you need to send the ECU back to us this MUST be done via a MoTeC dealer.
RossB
Postby Fueltank-Tai on Thu Jan 07, 2010 4:30 pm
Dear Ross:
How are you? I donot understand why Motec company donot make clear password function by tuner. Thank you so much.
Fueltank-Tai
