m800 mounting
m800 mounting
Postby prostang on Thu Nov 05, 2009 5:18 am
what is the best way to mount the box.
prostang
Re: m800 mounting
Postby IJ. on Thu Nov 05, 2009 7:35 am
Not sure about "best" but I use 2 strips of 50mm wide hookNloop then a cable tie as a "seat belt".
IJ.
Re: m800 mounting
Postby mr2andy on Thu Nov 05, 2009 8:52 am
mr2andy
Re: m800 mounting
Postby killerbee on Thu Nov 05, 2009 5:12 pm
I was concerned by vibration issues and wanted to isolate the M800. I also didn't want to risk voiding the warranty by removing screws from the ECU (probably wouldn't but didn't want to risk it). Mounted an aluminum plate to the car chassis using rubber vibration isolators. I got mine from Mcmaster Carr (http://www.mcmaster.com/#rubber-isolators/=4d7daz). Once the plate was isolated I wanted to attach the ECU to it. Used some aluminum angles and small 1/8 countersink aluminum rivets and adhesive backed rubber sheet. One of the 4 angles has a relief cut from it for the M800's plugs. One leg of the angle was riveted to the plate and the other had the rubber applied to it. If you pre-drill and layout the angles you can get a tight fit on the ECU body. To make it a little tighter you can slightly bend the outstanding leg inwards. I may add a tie-wrap but it is very tightly secured this way regardless.
Packaging things like this made it possible to mount an ignition expander and traction control unit on the other side of the plate (well within 500mm wire run limit). You can see the wiring to the the units in the first picture.
killerbee
Re: m800 mounting
Postby mr2andy on Fri Nov 06, 2009 12:45 am
I bought a sheet of Lexan and will be mounting the Lexan onto the chassis with vibration mount (http://www.vibrationmounts.com/Products1.htm any of those is fine depends on the weight)
I'll be mounting the CDI + the M400 + relays + fuses on the Lexan sheet. Well.. all of these are for a Toyota MR2 and it will be mounting on the wall between the trunk and the engine bay(MR2 is a mid rear engine car, in case you wonder)
I'm still working on the setup so.. all of these are just planning.
Hope it help..
mr2andy
Users browsing this forum: Google [Bot] and 50 guests
