SDL Power Supply
SDL Power Supply
Postby Martin on Sun Aug 03, 2008 5:13 am
Would it be possible to run an SDL from the download connector (0v, 8v, Can Hi, Can Lo) as a separate logger in a race car? The reason im asking is id like to plug a SDL into the downlaod connector of cars (racing in the same class running Mx00 ECU`s) to be able to do spot checks on certain engine parameters and log them to varify that they are within the rules.
The logging kit will be a backlit SDL and BL1 Gps all installed into a box that will be added into the car without modifying or adding any wiring. Would the ECU 8v supply enough current for the SDL and GPS to stay alive?
Re: SDL Power Supply
Postby DarrenR on Mon Aug 04, 2008 2:44 pm
Hi Martin,
I couldn't recommend doing that.
The 8V sensor supply from an M800 is 0.3A. The SDL draws 0.15A + BackLight, and the GPS around 0.2A, so it's over the rated current. It may work tho, and the sensor supply is protected.
You would be better off running the unit from a 12V, 5A/hr gel cell battery. That should give you ~10hrs running time on one charge.
Darren Reynolds
DarrenR
Postby Martin on Tue Aug 05, 2008 5:27 am
Thanks Darren :)
Return to ADL3, SDL3 and CDL3
