by knlmotorsport on Mon Aug 04, 2008 1:37 pm
I am running M800 gold box in a 1999 WRX STI and cannot get the taco to work. How do I cannect the tacho wire from the M800 to the back of the dash? ie any resistors needed?
knlmotorsport
by RossB on Mon Aug 04, 2008 3:16 pm
Pin B14 of the original ECU connector is the tacho signal. You will need a 2200 ohm pull-up resistor to 12 volts to make it work on an M800 output.
RossB
by knlmotorsport on Mon Aug 04, 2008 6:04 pm
Thanks Ross.......Does this mean I put a wire to the tacho wire and off that I put the resistor to 12v?
knlmotorsport
by RossB on Tue Aug 05, 2008 9:45 am
Yes that's correct.
RossB
Users browsing this forum: Google [Bot] and 25 guests
