Injector Battery Comp Power Enterprise
Postby alexflamingo on Wed Oct 14, 2009 9:40 pm
I need the value for Comp Injectors Injector Battery Powe Enterprise 18-ATL3-800 which are 800cc, I would also injectors Sard 63500th 700cc
Many thanks
alexflamingo
Re: Injector Battery Comp Power Enterprise
Postby RossB on Thu Oct 15, 2009 8:42 am
Hello Alex,
The Sard 63500 settings are:
Current 3
Peak & Hold ratio 4
Battery compensation.
Code: Select all
   Fuel Pressure (bar)
Volts      3   4   5
10      970   1121   1210
11      875   1004   1091
12      878   906   955
13      826   846   885
14      773   785   817
15      745   731   755
RossB
Postby alexflamingo on Thu Oct 15, 2009 4:15 pm
Thanks, the data for the Power Enterprise Injector Where can I get?
alexflamingo
Postby alexflamingo on Thu Oct 15, 2009 9:22 pm
After some research I discovered that the Power Enterprise are built by Denso, if you can find these specifications make me pleasure. Thanks
alexflamingo
Postby RossB on Fri Oct 16, 2009 8:28 am
If you have a Denso part number I can look and see if we have any data.
RossB
Postby alexflamingo on Sat Oct 17, 2009 7:24 pm
Hello Ross, the symbol of the injectors and dense 1001-87095 or 1001-ST095
alexflamingo
Postby RossB on Mon Oct 19, 2009 8:20 am
Denso 1001-87095 is a good number but we haven't got any battery comp data for this injector, sorry.
RossB
Postby alexflamingo on Mon Oct 19, 2009 6:14 pm
thanks for the answers, creeds to succeed in finding me these data?
Does a have conceive of which gives I can use for these injectors?
I have 3 autos that these injectors climb on and I have climbed on M800, if you succeed to make me have some datum I am thankful of it
Regards
alexflamingo
Return to Tuning discussions
