Hi
I want to fit a dash mounted switch to de-active the ABS as sometimes I compete on gravel. I can fit a switch in-line with the ABS fuse but I have no idea how this will effect the SDC2. I think it may also take away the wheel speed data and cause me some problems there.
I looked at the info in the Motec manual and it discussed removing or partially removing the ABS hardware and I wasn't sure if this was of help in my situation as I want to switch back and forth between ABS and no ABS.
Dave
