Hi Guys,
I am new here and a first timer using Motec.
I have been talking with Motec Engineers and seeing if we can find a solution for a project we are working on.I have not heard back from them as yet so I was hoping someone on here would be able to help.
We are building an Audi A4 2.0 Turbo engine for 900+ Hp and the issue is this.With the FSI injectors that are readily available on the market today and due to what we have available, we are only able to get a system that supports 600-650hp.
We have explored the option of running a chip on the stock Bosch Motronic ME-9 and then running a secondary standalone system to support 4 additional 870cc high impedance injectors positioned in the manifold.After battling with Motronic tuners for a solution we have finally given up and are focusing on sourcing a complete all in one standalone system that meets the following requirements:
Outputs
[list=]4 x Injector outputs—high ohm - 870cc[/list]
[list=]4 x FSI Injector outputs[/list]
[list=]1 x FSI fuel pump control (not sure what we will do here)[/list]
[list=]4 x ignition outputs[/list]
[list=]1 x 6-PIN Bosch/Seimens/VDO DBW throttle body[/list]
[list=]1 x 2-PIN boost controller[/list]
[list=]2 x 2-PIN camshaft position solenoid[/list]
INPUTS - Typical Motec fashion:
8 x Analogue voltage inputs—fully configurable including custom calibrations
6 x Analogue temperature inputs—fully configurable including custom calibrations
1 x Wideband Lambda input—for Lambda measurement and control
4 x Digital/speed inputs—for wheel speeds and function activation
Any help you guys have would be greatly appreciated.
Thanks so much
