Pascal wrote:Ohhhhhhh!
Dear Martin, it is fuel! I have very very similar problem from 2003 and 2006 Impreza, restricted 32mm GR. Super N, dog box and bla bla. Same things! FUEL! And ONLY fuel! After few days of suffering we did resolve it with fuel comp's and fuel maping and sensor readings.
Check compensation! Check readings of lambda and delay settings! Check that maybe is a bit wrong readings from sensors. Air, water and so on. Check that they are reading correct value! Maybe is a bit there and here wrong readings and on the end is lean! I did catch my self once with wrong calibration on air temp. sensor and was doing show for me that sensor! Must be there somewhere!
Question: Have water spray device for intercooler?
Regards Pascal
