Have an M800 and am running the LS2 throttle body and corvette pedal assembly. The unit calibrates and functions correctly. I have only specified a response curve with respect to TPD and avoided the other axis since I am not clear on its application, i.e. I am just happy to have a curve that I can adjust instead of machining a cam.
However, I just realized that I haven't a clue as how to set/adjust the idle. Is there way in the s/w to set a minimum angle ? Is it as easy as setting the curve to a nonzero value for zero TPD ?
