CAN protocol used?
CAN protocol used?
Postby IJ. on Sat Sep 19, 2009 10:55 pm
As per the topic, what do M800's use?
(I have a Transmission controller that can do a Native PCS, J1939 and TGM.)
I suspect MoTeC have a propriety protocol.
thanks in advance for any info.
IJ.
Re: CAN protocol used?
Postby DarrenR on Wed Sep 23, 2009 4:00 pm
Yes we use our own data protocol.
Altho we can read J1939 data using an ADL/2/3, SDL or ACL (not m800).
What do you wish to do with the trans controller?
Darren Reynolds
DarrenR
Postby IJ. on Wed Sep 23, 2009 9:08 pm
Thanks for the reply Darren,
Would just cut down on some of the hard wires if I could get the M800 to talk to the Trans controller ie: TPS/Temp/Road speed/Map and so on.
IJ.
Postby DarrenR on Fri Sep 25, 2009 3:40 pm
Fair enough.
Is the trans controller configurable in its reception of CAN data at all?
Darren Reynolds
DarrenR
Postby IJ. on Fri Sep 25, 2009 4:00 pm
Not really other than check boxes in the J1939 section.
IJ.
Postby IJ. on Tue Sep 29, 2009 8:35 am
Have been in contact with the PCS owner and he's looking at increasing the CAN bus speed, it's currently 500k am I correct that ours runs at 1000k? (1Mb/sec)
IJ.
Postby IJ. on Tue Sep 29, 2009 9:49 am
After speaking with Steve T this morning this issue is a non issue as the M800 can't transmit J1939 in anyway.
IJ.
Postby RossB on Tue Sep 29, 2009 10:00 am
We can make the details of our CAN protocol available to PCS if they wanted to make a configuration to accept our data stream.
RossB
Postby DarrenR on Tue Sep 29, 2009 10:25 am
Yes we normally use 1Mbit/s CAN baud rate, tho the m800 can autobaud to 500kbit/s. All our dashes have configurable baud rates of at least 1M, 500k and 250kbit/s. Some of our other CAN devices only work at 1Mbit so it will depend on what else you want to connect on the CAN bus to if you can run at a different speed.
The M800 can transmit a custom set of data in 3 predefined formats,thats as far as it goes.
Unless the trans controller is fairly configurable in its CAN reception it won't receive data from at m800 directly, tho an ADL2/3 could be used to convert the CAN messages as they are fully configurable.
Darren Reynolds
DarrenR
Postby IJ. on Tue Sep 29, 2009 6:19 pm
Thanks for the replies guys!
I'll suggest Russ get in touch with you for your CAN protocol details!
IJ.
Users browsing this forum: Bing [Bot] and 2 guests
