Wiring help! Motec CAN female connector - Deltron 716-0-0501
Postby mr2andy on Wed Sep 23, 2009 2:02 pm
Guys,
I bought the DEM 724-0501 (Non Latching) connector from Motec and have no idea how to wire it up with the wiring harness. Can anyone help?
Andy
mr2andy
Re: Wiring help! Motec CAN female connector - Deltron 716-0-0501
Postby MarkMc on Wed Sep 23, 2009 3:38 pm
Hi Andy,
The wiring is on all the ECU drawings for the M400, M600 and M800 but for the record the pin out is:
1: 0v comms (ECU B14)
3: 8v (ECU A13)
4: CAN Lo (ECU B24)
5: CAN Hi (ECU B23)
Postby mr2andy on Thu Sep 24, 2009 12:22 am
Thanks Mark,
Which pin is no1, no2, ... on the plugs?
By the way, do I crimp the wires directly to the pin on the connector or soldered them on and wire heat shrink it?
Andy
mr2andy
Postby IJ. on Thu Sep 24, 2009 7:41 am
Grab the data sheet here Andy
http://www.motec.com.au/filedownload.ph ... docid=1214
M800 pins crimp directly to the wire no need for heatshrink as it won't go into the weather seals on the plugs.
IJ.
Postby mr2andy on Thu Sep 24, 2009 9:34 am
Thanks buddy... = )
mr2andy
Postby IJ. on Thu Sep 24, 2009 3:08 pm
Very welcome Andy!
It's a good idea to get the correct crimper for these pins as well as the hole in the body of the plug doesn't leave room for anything other than a nice roll crimp on the insulation.
They're a bit spendy but worth their weight in gold :)
IJ.
Postby mr2andy on Tue Sep 29, 2009 5:48 am
Guy,
my problem is... by looking at the DEM adapter.. i don't know which pin is 1, 3, 4 and 5?
mr2andy
Postby IJ. on Tue Sep 29, 2009 8:10 am
mr2andy wrote:Guy,
They're marked pin #1 is the one with the red pin inserted :)
IJ.
Postby mr2andy on Tue Sep 29, 2009 8:46 am
My bad.. I saw that when I took the part off the plastic package...
Thanks for the information bro..
Andy
mr2andy
Postby IJ. on Tue Sep 29, 2009 8:48 am
WHAT!!
I went out in the cold at 7am for nothing??? :D <jk>
No probs Andy!
IJ.
