m600 with ls1 coil
m600 with ls1 coil
Postby SniperxXx on Sat Aug 22, 2009 7:39 am
hi guys i need help
i have m600 motec with 6 ls1 coil without igniter for 2jz engine so wich taip of igntion i have to us ?
i her thar is msd but i dont no wich one thanks for help :)
SniperxXx
Re: m600 with ls1 coil
Postby skyline_stu on Sat Aug 22, 2009 4:07 pm
Hi, I take it that this is a non turbo engine with a dizzy fitted?. If this is the case, you can use a single LS1 coil triggered straight from the ECU, as the coil has an inbuilt ignitor. Check the documents page on the website, Download the Denso coil M32 drawing.
Hope this helps
Stu Cornall Tuning Services
MoTeC Installations and Calibration Engineer
Wide Bay QLD
skyline_stu
Postby SniperxXx on Sun Sep 13, 2009 4:43 am
thanks skyline but the ls1 coil is Denso with 4 pins i need igntion between the motec and the 6 coil ?
thanks for help....
SniperxXx
Postby RossB on Mon Sep 14, 2009 9:43 am
Set the ignition type to "1". The number of coils needs to be set to "6" if you have the coils wired sequentially or "3" if you have them wired as wasted spark.
Use the following values for your Dwell Table:
Code: Select all
Volts   Bat Comp (msec)
8   7.7
9   6.2
10   5.1
11   4.4
12   3.9
13   3.5
14   3.2
15   2.9
RossB
