I've tried to search the forum archives, but am told that the search term "lambda" is not allowed as it is too common!....
I have an old M8 ecu. This is running a 4-litre Judd EV. I have struggled with a lack of power above 9,500 rpm and at the weekend swapped to a map from a different engine - all sensor settings were from the original map, with the fuel and ignition maps above 4500rpm spliced together.
Suddenly, I have more power than I can deal with! In addition, a strange rythmical cutting of the engine (about every 6 seconds for about 0.25 secs) at 3,000 to 6,000 rpm when above 65C has gone...
I am however concerned about the AFR and I would like to check and maybe make map changes on the track.
From what I have read, I can only use a Bosch LSM 11 (0 258 104 002) sensor with the M8. I already have the wiring in the loom for it. I hope I can log lambda in the ADL I have.
Can anyone tell me whether the LSM 11 will give me what I want? As a novice... what lambda values should I be aiming at, what ones are dangerous?
Thanks,
Oliver
