Rotary Accel Enrichment
Postby Martin on Thu Jul 31, 2008 6:20 am
Do rotaries require more accel enrichment than piston engines?
Ive tried running it with overrun fuel cut and without, also adding extra fuel on overrun to keep the fuel in the inlet on overrun.
This particular engine is a stock RX8, 3 injector per rotor type. (6speed gearbox)
Injectors are staged, 1 at port (primary) 2 higher up (secodary)
logging
Re: Rotary Accel Enrichment
Postby MarkMc on Thu Jul 31, 2008 10:20 am
Hi Martin,
I take it from the logging you get a big lean spot when you hit the throttle? Have you tried increasing the accel enrichement sensitivity?
What sort of settings do you have?
Postby Martin on Thu Jul 31, 2008 4:07 pm
Hi Mark,
Yes that lean spot is the problem as you get on the trottle.
IJPU = 10ms
Baro reading was 84.7 Kpa during this session
Could it need any more than this??
fuel clamp.jpg (64.26 KiB) Viewed 19051 times
Postby ElsmoortelG on Thu Jul 31, 2008 5:26 pm
Hi Martin,
How does your project looks like ? Is it an original 13BMSP or did you modify something ?
Is the problem over the entire RPM range or only at a certain point.
I added the accel setting of our peripheral ported rotary.
Maybe this helps.
accel settings.doc
Accelerator settings PP rotary
(187 KiB) Downloaded 1253 times
ElsmoortelG
Postby Martin on Fri Aug 01, 2008 1:27 am
THis is a GrpN Track car, Still with complete original wiring. Ive just added 2 sets of Millspec connectors to splice into the chassis harness and engine harness to pick up neccesary wires. The standard display cluster, abs pump, alternator are all working. THe motec controls all engine parameters, Fuel, Ign, DBW. These are not shared with the standard ECU, allthough swopping back to standard ECU takes 2minutes.
The Engine is still stock (13B MSP), and yes the problem is over the whole RPM range. The thing is that it wants more fuel than i expect it to take so this is why im looking for a problem elsewhere. But first id like to find out if this is really uncommon for Rotaries to want so much Accel Enrichment.
I must add that the fuel is Premixed, the OPM is diconnected.
Thanks for your accel table, i appreciate your input!
Postby Martin on Fri Aug 01, 2008 1:50 am
Had a look at your Accel Settings , just a few Q`s...what is your IJPU? and what is your Accel sensitivity?
Postby ElsmoortelG on Fri Aug 01, 2008 7:27 am
Hi Martin,
Our IJPU is 20 ms but it could be a bit less because our Effcy% is max 60 %.
For Fuel acc sens see doc.
The engine run's with RX-8 primaries and 1600cc secondaries
We run it at 0,93 lambda.
fuel acc sens.doc
Fuel Acc Sens
(29.5 KiB) Downloaded 1231 times
ElsmoortelG
Postby PeteS on Mon Aug 04, 2008 9:10 am
Hi Martin
The short answer to your question is YES, I have not tuned a lot of Rotaries but the ones I have, had some big numbers in the Accel, over 100 in some cases with the IJPU at 12. The only problem with settings like this is you need to make sure your throttle sensor has no noise on it as this will cause false triggers so to speak.
MoTeC Research Centre, Melbourne Australia
PeteS
Postby injectordynamics on Fri Aug 08, 2008 2:59 pm
Take a close look at the hysteresis settings for the secondaries, and the amount of enrichment associated with the secondaries coming in.
Your 1600cc secondary injectors are highly non linear in the lower range which is adding to the problem.
And yes, rotaries typically need large amounts of accel enrichment.
Paul Yaw
www.injectordynamics.com
injectordynamics
Postby 20B on Wed Jul 22, 2009 8:36 am
Pete, numbers of over 100 in what table ? What sort of setup do you have in the accel ignition tables ? I'm working on this at the moment so any advice helpful.
Mazda 1993 RX7
20B N/A engine
20B
