Programming Question ?
Discussion and support for MoTeC's Shift Light Module
Postby killerbee on Sat Aug 15, 2009 7:45 am
Is there a way to get the SLM to flash once a specified rpm is reached (running on CAN from SDL)? Maybe I have been watching too much F1 but it seems like a helpful feature. I have looked but if its there I have missed it. Please don't tell me I need to get an ADL2 to have this feature :lol:
killerbee
Re: Programming Question ?
Postby IJ. on Sat Aug 15, 2009 8:37 am
Yes just configure it using a Shift Light.
Dash Manager>Functions>Shift Light Module>ADD>Patter Mode Shift Light>Activate Pattern at xxxx RPM.
IJ.
Postby Martin on Sun Aug 16, 2009 6:58 am
Setup a 2d table to make a GP on/off channel = 1 when the RPM is reached. Now you can Activate/deactivate (user conditions) a channel driving you SLM condition if this channel is true for a certain time, and then deactivating after the time has elapsed that you want the LED on for.
Postby killerbee on Fri Sep 11, 2009 6:44 am
Martin,
Do you have example of this is an SDL configuration file ?
IJ,
I did look at your suggestion and as far as I can tell the SLM control from the SDL does not address flashing. Please tell me why I am wrong.
killerbee
Postby IJ. on Fri Sep 11, 2009 9:34 am
Sorry KB I misread your question, so you want a light to flash xx times once you hit yyyy rpm?
Or do you want it to flash once?
IJ.
Postby Martin on Fri Sep 11, 2009 3:30 pm
Killerbee,
Send me your config, ill put it in for you
Cheers
M
Postby figgie on Wed Nov 04, 2009 10:24 am
Hmm
I know I asked MoTeC a while back to include flashing as part of the SDL as it very useful..
wonder what happened to that request...
here we go.
viewtopic.php?f=14&t=45&p=3974&sid=394963b62ef4b9ff740168b8ebcbc292#p3974
figgie
Postby JamieA on Wed Nov 11, 2009 12:55 pm
Flash is a part of the soon to be released SDL3 SLM setup.
I doubt that it will be back ported to SDL.
-Jamie
JamieA
Return to SLM
