CAN limitation in SDL?
Re: CAN limitation in SDL?
Postby SportsCarRacer on Thu Aug 13, 2009 10:50 am
Jamie, i can give you more info and format/sample .dbc files if you require for the convertor...i've written some for the PLM's we use with CAN on ATI, also many other things.....it as as ElectronSpeed says, the .dbc format is auto-industry wide pseudo-std for can message templates...CAN database file. Allows comms with any CAN device using common format.
Happy to provide some samples...your local mazda turbo man ;-)
SportsCarRacer
Postby JamieA on Wed Aug 19, 2009 10:45 am
Thanks guys. This request has been added, but at present it isn't being worked on due to prioritising. I will let you know when it gets started, and I'm sure that at that point, I will be asking for more info...
thanks.
-Jamie
JamieA
Previous
Return to ADL3, SDL3 and CDL3
