Hi There.
Can anyone shed some light on this.
We have an M800 and an ADL2.
We have made the can bus up and the dash is seeing the ecu and receiving data.
If I plug the laptop in using the can lead and try to work on the ecu it will not see the ecu and the connection box on the ecu manager is flashing between unable to connect and time out.
The only way I can use the lead is if we remove both resistors from the bus, but then upon disconection the ADL is not getting data. Or disconnect the ecu from the bus.
We have made the bus exactly as the manuals say, have checked the resistors and wiring repeatedly and all is ok.
Am I right in assuming that if I am connected to the bus I should be able to work on either the dash or the ecu?
I have tried the USB cable aswell can see the dash but not the ecu. Should I be able to work on the ecu with the usb?
Any help would be great.
Alex.
