Display Next Line (SDL)
Postby Ben-S on Mon Jul 20, 2009 10:46 am
I have been trying to avoid asking this question as I'm sure I'm missing something fairly obvious but I cannot get my SDL to display the next line no matter what I do. I can switch display "modes" but cannot get the next line to come up. I have a simple switch feeding the "display next line" parameter and have confirmed that it works in the monitor channels window.
Attached is my calibration file for review...
S2000 - M800 - E888.U16
Current SDL Config
(234.85 KiB) Downloaded 1174 times
Ben-S
Re: Display Next Line (SDL)
Postby RossB on Mon Jul 20, 2009 12:00 pm
You have to set up the channels for the Mode, Next line etc. This is done in the Display Setup menu under the Channels Tab. You have a display Next line button setup but I cannot see a Mode input in your configuration?
RossB
Postby Ben-S on Mon Jul 20, 2009 12:17 pm
Embarrassing, as I suspected (how did I miss that :oops: )
There is no mode button needed to change modes, I have it setup to change modes when the alarm ack button is pressed for more than 2 or 3 seconds (didn't seem worth adding a separate button). Funny the function I took the back way around works but the one that should be simple doesn't.... I made the poor assumption that the "display next line" button would automatically setup to do so. Thanks for the quick response :)
Ben-S
Return to ADL3, SDL3 and CDL3
