Jet Ski Video
Information about MoTeC jet ski installations
Jet Ski Video
Postby PeteS on Fri Jul 17, 2009 1:40 pm
Hi all
Below is a link to YouTube where you can view a video we recently created:
The main reason for recording it was to show some exciting footage that we got while testing our new Video System.
We decided to test our standard ECU for water resistance. All MoTeC ECUs are produced with a water resistant coating and the video shows how we dunked an ECU under water while the engine keeps running.
However, we do not recommend that you treat any of our electronics in this manner. The coating is only thin and if there is any water left in contact with the boards, it will eventually corrode through the protection. This will then definitely lead to unreliability issues in the future. MoTeC highly recommend not running any standard ECU that has been submerged in water. Return it to MoTeC via your local dealer.
It made us realise that in installations such as PWCs, water ingress to the ECU will be almost unavoidable and therefore MoTeC has produced a Marine ECU. This ECU contains the same circuit board as a standard ECU but the case is completely filled with a polyurethane potting compound to seal the electronics inside providing a much better water resistance. All PWC ECU kits are supplied with this marine version ECU.
http://www.youtube.com/watch?v=D_scyqIsyQc
MoTeC Research Centre, Melbourne Australia
PeteS
Re: Jet Ski Video
Postby IJ. on Fri Jul 17, 2009 10:54 pm
Is this the same potting as used in the SLM?
IJ.
Re: Jet Ski Video
Postby PeteS on Sat Jul 18, 2009 7:25 am
IJ. wrote:Is this the same potting as used in the SLM?
Hi
No its quite different
One of our engineers spent a lot of time looking for a compound that met the following criteria
Conducts Heat
Light as possible
Removable from the board
Non corrosive
He found something eventually
Took a long time with lots of testing.
PeteS
Re: Jet Ski Video
Postby IJ. on Sat Jul 18, 2009 9:04 am
Nice vid, Steve's now a movie star! :)
Very different to the SLM then!
IJ.
Re: Jet Ski Video
Postby SHOBiz on Sun Jul 26, 2009 7:34 am
GoTTa loVe tHat poTTing. ThaNks PeTe, MoTec...
2008 Yamaha SHO WaveRunner
Motec M400 / R&D Performance Stage 3
SHOBiz
Return to Jet Ski applications
