Updating M800 ECU
Updating M800 ECU
Postby AWP on Thu Jun 25, 2009 7:01 pm
Hi guys. :)
I have recently started riding a 08 Yamaha R1 with M800 ECU and ADL, when I try and connect to the ECU I am asked if I would like to update it.
If I do so, will all settings remain the same, or will they return to some kind of default setting?
Thanks. :)
AWP
Re: Updating M800 ECU
Postby RossB on Fri Jun 26, 2009 9:36 am
You should be getting a message telling you what version of software is installed in the ECU, can you tell me what version it is.
In most cases the upgrade is straightforward but I would always recommend that you install the old version in to your PC and get a bacu up copy of the configuration file. The configuration file is up-grasded at the same time as the ECU but it is always a good idea to have a back up copy just in case something goes wrong during the upgrade.
RossB
Postby AWP on Fri Jun 26, 2009 7:09 pm
The firmware version is V2.33K
I can't see a software version that matches, or does V2.30 work?
Many thanks. :)
AWP
Postby RossB on Mon Jun 29, 2009 10:57 am
Yes that should work ok.
RossB
Users browsing this forum: Google [Bot] and 9 guests
