Rotary Individual trim
Postby Martin on Thu Jun 18, 2009 2:12 am
Ive got a SKM working nicely on a 13B MSP
Question is...If I do an Indv trim per rotor is it advisable to trim both the leading and the trailing or just the leading Ign event since thats the Ign event that triggers initial combustion?
M
Re: Rotary Individual trim
Postby RossB on Thu Jun 18, 2009 9:22 am
I would apply the trim to both and keep the split constant. Also depending on how much split you have and how much trim you apply you could end up with the leading plug firing at the same time as the trailing (or even after!).
RossB
Postby Martin on Thu Jun 18, 2009 2:58 pm
Im running about 6 deg split at the point where I want to do the trim.
The trim is not enough to go into negative split. But thanks...ill apply the trim to both leading and trailing.
Cheers
M
Users browsing this forum: Google [Bot] and 27 guests
