rx7 s5 start tune
Files not endorsed or guaranteed by MoTeC. Use at your own risk
rx7 s5 start tune
Postby beefcake on Sat May 09, 2009 12:27 pm
its a tough one but if your close enough it would be nice :D
13bT half bridgeport ive got M2R and motec cdi and merc coils, 4x1600 blue tops, 3 bar map, and your bosch/delco coolant and air temps,
the 4 injects are sitting in a efi hardware ida throttlebody too.
my car runs and starts but its running super fucking fat, i cant even give it throttle :lol: so im really just chasing a better fuel map for now as ive got the rest sorted out good enough
PB of 10.01@138 mph
http://www.youtube.com/watch?v=w2k_idn71ro
beefcake
Re: rx7 s5 start tune
Postby beefcake on Sat May 09, 2009 11:48 pm
ohh yeh i forgot to mention the reason im asking as i ordered through my dealer a m2r too suit s5 turbo, i got a s4 N/A setup and RX8 setup in my unit to start with, and i don't think the timing maps would be suitable for my big boosted combo :lol: , and the fuel maps would be way off to start with as well, its no biggey but if i can get a leg in the door a bit easier before hitting the dyno it would be great 8-)
thanks heaps in advance guys :)
PB of 10.01@138 mph
beefcake
Postby beefcake on Mon May 11, 2009 10:00 pm
beuler beuler beuler :lol: anyone got a turbo timing map i can at least borrow, im putting the wide band in by tomorrow so maybe i can get somewhere roughly with a fuel tune, but ignition is still not close enough :D
PB of 10.01@138 mph
beefcake
Postby 20B on Wed Jun 17, 2009 9:51 pm
You will have fun getting a nice idle on that throttle body with 1600cc injectors and no idle speed valve. I struggle to keep a stock 20B with factory injectors and multithrottle manifold steady at 1200rpm. It takes some time to get it nice but its very sensitive to small adjustments etc. You really need a wideband otherwise your flying blind, I also find an egt helps with seeing whats going on with ignition timing. I am running one wideband and one egt per rotor which helps with trimming each rotor mixture, expensive but great to see whats really going on in the engine ! Just be careful of how much fuel your dumping in there as rotor plugs foul at the drop of a hat.
Mazda 1993 RX7
20B N/A engine
20B
Postby beefcake on Thu Feb 18, 2010 10:10 pm
so much has happened in a year, sorry i missed this post, the car is running 100% perfect, the wideband is functioning, the idle is like a stocker, even for a bridgeport :lol: , i raced it last weekend for the first time and it could not have been any better for a first time out 8-)
Thank fuck i chose motec , as its funny listening to the other competitors at the track with there ghost tune problems :lol:
Everything is all roses now :mrgreen:
PB of 10.01@138 mph
beefcake
Postby cheefbea on Wed Jul 13, 2011 7:30 pm
Hi dude im after a base map for my m4 also. Running a s4 bridgeport turbo. Any help would be awsome.
cheefbea
Postby cheefbea on Wed Jul 13, 2011 7:32 pm
primary injectors 560cc secondary 1680cc
cheefbea
Return to User Posted Tune Files
