Hi All
i have a m800 oem fitted to a 2005 N11 GPN car and it has had a small problem hot starting for some time now !
cold starting was extreamly good and hot starting was ok but it just spun over for a few seconds before it would fire up
but recently the hot starting has become a major problem it will some times take 20/30 seconds to fire up when hot
mostly it will still start ok from cold, (but not always), i have viewed live data and the problem appears to be associated with the cam signal as when cranking i get ref/sync errors, no ref , ref rnt errors, i have replaced the cam sensor with a new one and pinned out the wires back to the ecu and the are all fine when the engine does fire up it runs perfectly with no errors at all, the battery voltage is good when cranking
can i dissable the cam requierment dureing cranking or reduce the sensativety ? not sure if this will work ?
any help or sugestions would be much appreciated
thanks guys
