solenoid control
solenoid control
Postby insomnia on Wed May 06, 2009 7:07 pm
i search the solution to control two solenoid for increase or decrease the turbo boost..
is that possible with the M800?
the wastegate use a spring for 7psi boost. i want to use air pressure (like a pneumatic shifter)to have more boost,
but not more as 30psi. i use a wastegate from Tial.
any idea?
Thanks for all infos
insomnia
Re: solenoid control
Postby DarrenR on Wed May 27, 2009 5:50 pm
So your waste gate has a port on both sides of the diaphragm?
You only need one control valve, and set it up as per the drawing here
http://motec.com.au/filedownload.php/v14.pdf?docid=1307
The boost control setup in the m800 is comprehensive and you may need some help in setup. If so, please consult your local motec dealer.
Darren Reynolds
DarrenR
Postby insomnia on Fri Jun 05, 2009 6:13 am
Thank you for this!
And what's a good valve to do this job? i think the valve need to work quickly ?
Francois
insomnia
Postby garykenward on Sun Jun 07, 2009 7:47 pm
Get yourself a 4-port solenoid and that will controll both ports of the wastegate from one output from ur motec.
garykenward
Postby Martin on Mon Jun 08, 2009 3:42 am
How did you plumb it? Solenoid?
Id very much like to see your installation
M
Users browsing this forum: No registered users and 24 guests
