by MarkMc on Tue Jun 02, 2009 3:42 pm
Hello Salsol,
Our Low end RPM limit for the Anti-Lag is the function you are looking for, we just don't call it Rotational Idle. But there are probably a couple of things to clarify.
When you run a car with anti-lag (especially Group N cars) the throttle body is usually held open all the time, obviously this will mean the idle speed is excessively high. In order to keep a check on the idle speed the "rotational idle" function is used. Below a set throttle position the ECU will cut fuel (not ignition) to random cylinders so they make no power and therefore the idle speed comes down. The side effect is you are pumping fresh air through cylinders and the engine can run cooler. I would be suprised if any rotational idle system cut ignition and allowed fuel to build up in the exhaust system when you want the car idling, this would genreally lead to some rather unwanted explosions and fires.
Ironically enough this is the exact opposite of when the anti-lag is on where you do want the explosions and fire but this is at high RPM. On anti-lag with high RPM you cut the ignition and add fuel to get the energy in the exhaust to keep the turbo spinning.
