wrx7 pnp 5 bar map pin out
Postby Julius GE on Mon Jun 01, 2009 5:37 pm
dear all
i'm using wrx7 with pn8274 pnp ecu.
i would like to change the stock map sensor with 5 bar ti sensor, could anyone advise which pin out are for map sensor, 5v and 0v, please?
and also which 0v pin out for reff and sync signal from the ecu?
many thanks.
Julius
Julius GE
Re: wrx7 pnp 5 bar map pin out
Postby RossB on Tue Jun 02, 2009 10:02 am
You SHould be able to use the existing wiring for your MAP sensor. The pin numbers are as follows:
B8 - MAP input (AV2)
B9 MAP 5V
B19 MAP 0V
B10 Sync 0V
B11 Ref 0V
RossB
Postby Julius GE on Tue Jun 02, 2009 12:53 pm
thank you for your kind reply Ross,
one more help please if i would like to replace the MAF with bigger piping, which is the pin for Air temp?
Julius GE
Postby RossB on Tue Jun 02, 2009 2:04 pm
The Air Temp sensor is on Pin B27.
RossB
Postby Julius GE on Tue Jun 02, 2009 2:19 pm
thank you for all your help mate.
Julius GE
Postby Julius GE on Mon Jun 15, 2009 12:50 pm
Hi Ross, the heat from external wastegate accidentally burn off the wiring harness. The heat insulator was burnt off.
We've managed to fix the wiring but we couldn't find the right wiring pattern for some outputs and inputs.
Could you kindly advise which pin for:
Outputs: Fuel pump, Electric fans and Idle motor.
Inputs: Aircond request, speed and anti lag request.
Thank you for your kind attention.
Julius GE
Postby RossB on Mon Jun 15, 2009 5:17 pm
PM Sent.
RossB
Return to M800 Plug-In ECUs
