Lean Angel
Lean Angel
Postby Ralle#67 on Fri Jun 12, 2026 5:55 am
I use a Bosch MM 5.10 in my Ducati to calculate the lean angle.
However, the values in my log data don’t seem plausible or accurate enough to me.
So I’m wondering if there might be an error in my settings, or if my package is even capable of calculating the data correctly and precisely.
If that’s the case, I’d probably need to switch to a 6D IMU.
Thanks for the help,
Ralf
Ralle#67
Re: Lean Angel
Postby Stephen Dean on Fri Jun 12, 2026 10:54 am
Hi Ralf,
Which Display/M1/Package are you using?
What is the impausability in the data that you are seeing?
Has the unit been calibrated?
