Wastegate CO2 control w/Dual MAC Valves
Postby TurboTito on Sun Mar 15, 2026 2:38 pm
I am using individual Low Side Injector signals to trigger both Increase and Decrease MAC valves with CO2 control. They share a 12 volt constant power.
I'm not sure if this is normal, but it doesn't look normal to me.
With engine idling, the decrease valve will show 12 volts but I confirmed that the valve is actually closed.
The increase valve shows 0 volts.
I don't want to test the boost strategy until I know this is okay.
TurboTito
Re: Wastegate CO2 control w/Dual MAC Valves
Postby SOReilly on Wed Mar 18, 2026 2:50 pm
Are you using GPR firmware or a partner package?
SOReilly
Postby TurboTito on Wed Mar 25, 2026 9:28 am
SOReilly wrote:Are you using GPR firmware or a partner package?
I use the JRR firmware, which I believe is a modified version of the GPR firmware that John tweaks how he sees best fit.
TurboTito
Postby SOReilly on Mon Mar 30, 2026 11:34 am
The reported output voltage will be 12V if the actuator is off.
Unless the low side driver is allowing a path to ground it's expected to see the supply voltage measured.
SOReilly
