by Stephen Dean on Thu Feb 26, 2026 1:45 pm
Hi Ralf,
The Engine Speed Pin Threshold should be left at 0.0V as the signal is crossing at 0.0V.
As long as the sensor is configured correctly, I see not reason to change from the existing tested Mag sensor, to an aftermarket Hall sensor.
The Sync is set as a Mag sensor in this specific usage, but as you are not reading a Mag sensor, but a MAP sensor for the signal, then the Threshold is configured based on how the signal moves on the induction pulse. With a MAP based sync setup, there are no fixed settings that we can supply, as each installation is different. Even the same sensor on the same engine will often require different settings.
