worksheet download
worksheet download
Postby zaid on Wed Aug 20, 2025 10:26 pm
Hello all Im new to Motec staff and I have work with old M1 version 1.4 now I have updated my software to 1.5.0.0424 now I have couple of issues :
1 – I cant load my old worksheet layout from older versions
2 – the efficiency tables it not colored anymore just gray
zaid
Re: worksheet download
Postby SOReilly on Thu Aug 21, 2025 12:52 pm
Hi Zaid,
Tune 1.5 does not use the workbooks/worksheets structure of 1.4. instead, the workspace is initially created by selecting a template then you can add or change components as you need. The adjust tree structure can be edited if you wish to add more groups. You can also add worksheets for specific tasks, the template already includes some you can use as an example e.g individual cylinder fuel/ignition.
Table surface colouring can be toggled on and off, right click the table then under Display ensure the Show Surface Colour option has a check mark next to it. (I think the current workspace template this may be unintentionally checked off by default)
SOReilly
