Blink Marine Keypads
Postby Nickwinsor on Fri May 09, 2025 5:38 pm
On an M150 running the 86 package, you can configure a keypad to connect directly to the ECU. I'd like to do this with a Blink Marine keypad (PKP-1600-SI) - being a CANOPEN device like the Motec ones, does this mean it's compatable and I just set the base ID to suit the keypad? If it's not compatable, I do have a C125 dash. Is it possible to set this keypad up in the dash and configure latching / momentary buttons etc?
Thank you,
Nick
Nickwinsor
Re: Blink Marine Keypads
Postby MikeD on Sat May 10, 2025 5:45 am
I don't know regarding direct control by the M1 (I assume it will not work) but it's possible when using the C125 for sure.
If you need some help then let me know.
Regards,
Mike
MikeD
Postby SOReilly on Mon May 19, 2025 2:25 pm
Hi Nick,
The Blink Marine keypads can be configured to emulate a Grayhill (MoTeC) keypad.
If your keypad is configured for this then it would essentially function exactly the same as if it were a MoTeC keypad.
SOReilly
