NathanB wrote:It is too hard to comment without seeing your config.
You can duplicate you input pin to allow for measuring the raw voltage on your input pin
Otherwise depending on the wiring configuration of your sensors, something could be wrong there - leading to the AV going to maximum voltage when the button is pressed?
