Licensing Error
Licensing Error
Postby shantim on Fri Apr 04, 2025 10:21 pm
I tried connecting M142 ECU (M142 #19459 Production) today to a diesel engine. The ECU gets connected however whenever I try to load a package and click on 'Send' it doesn't gets connected and shows an error : The current ECU Licence does not allow this Package to be sent. Please find the attached images.
Kindly guide me how to update the License.
Thankyou.
shantim
Re: Licensing Error
Postby David Ferguson on Sat Apr 05, 2025 2:43 am
Your MoTeC Dealer needs to email you the license, you install that, and when you connect the ECU it will indicate a new license is available and install it.
So, contact your MoTeC dealer.
Re: Licensing Error
Postby SOReilly on Sat Apr 05, 2025 8:29 am
Currently this M1 is licenced for GPR-DI which is for gasoline direct injection engines.
If you want to use GPR Diesel you would need to purchase this licence from a MoTeC dealer.
You can either trade in your GPR-DI licence to reduce the cost of the new licence or keep GPR-DI and add GPR Diesel so you can use either firmware.
SOReilly
