Engine not started when ET over 63 degress
Postby thorstengsxr on Tue May 19, 2009 4:52 pm
HI
I had an intersting Problem. I have a GSXR 1000 K5 with M800. The engine is running fine but wehn I want start the Engine over 63 ET nothing work. Under 63 ET I push the starterbutton und 1 sec. later the engine is running fin. As anybody her a idea :?:
regards Thorsten
thorstengsxr
Re: Engine not started when ET over 63 degress
Postby MarkMc on Fri May 22, 2009 4:46 pm
The first thing you need to do is connect a laptop to see what the ECU is doing. You need to know if the ref/sync sensors are giving the right information or if it is simply to do with your fuel/ignition compensations.
Users browsing this forum: Google [Bot] and 33 guests
