PDM 15 power up
PDM 15 power up
Postby jealand on Mon Jan 13, 2025 4:23 pm
Rookie question I have a PDM 15 and keypad.
I have the harness built and am trying to power up/configure on the bench.
I have 12v Positive to the lug and 12v Negative to the battery negative pins in both connectors. Plus 12 v +/- to the key pad with the can bus connected.
UTC is connected to can hi and low plus battery negative for 0 volts.
Windows sees the UTC but the PDM manager does not seethe PDM.
Nothing out of the PDM or the keypad. No clicks no lights on the buttons nothing.
Is there something I’m missing? Thanks in advance.
jealand
Re: PDM 15 power up
Postby David Ferguson on Tue Jan 14, 2025 1:58 am
Check to make sure CAN Hi and CAN Lo aren't swapped. Normally I would also ask about a terminating resistor, but the UTC has one internally, so that is seldom is issue.
Re: PDM 15 power up
Postby Stephen Dean on Tue Jan 14, 2025 8:38 am
If the CAN is the correct way around, try sending a Firmware update into the PDM.
Re: PDM 15 power up
Postby Merlin on Tue Jan 14, 2025 1:06 pm
Also a trap for new Players who have never had a Dash or PDM is
You need to download the File by clicking the Down arrow at the top of your screen
You then edit the file and resend it back to the PDM by clicking the upload Button
JP
Merlin
Re: PDM 15 power up
Postby jealand on Wed Jan 15, 2025 1:42 pm
Thanks everybody. David had it :? Green and white backwards.
jealand
