ADL and/or SDL as Standalone
Postby insomnia on Fri Dec 27, 2024 4:13 am
Hello guys,
Back on an older project, i try to use an ADL and a SDL with an ECU from MaxxECU.
We know the CAN ID for every channel we want.
The issue are:
-Can we send the MaxxECU CAN ID to the ADL or SDL Dash ?
-And if yes, how to do this ?
Any advice?
Thank you for every info....
NB: I speak from two Dashboard because we have two Vehicle...
Cheers
Francois
insomnia
Re: ADL and/or SDL as Standalone
Postby David Ferguson on Fri Dec 27, 2024 4:28 am
I would try creating your CAN template in the ADL dash manager as a test to see if you can get everything.
The one issue with the SDL is that it won't allow you to create/edit CAN templates, but you can use the ADL2 Dash Manager to create/edit CAN Comms templates then move them to the SDL Comms folder.
Postby insomnia on Fri Dec 27, 2024 5:40 am
Thank you David for your quick reply.
I will try that and let you know how i go.
Do you think this can be easier with a C125? Found one under the stairs!!
insomnia
Postby David Ferguson on Fri Dec 27, 2024 9:18 am
Well, a C125 can import a DBC file, and the MaxxECU has a DBC file found here:
https://www.maxxecu.com/files/Documenta ... l_v1.3.zip
Postby insomnia on Sat Dec 28, 2024 2:52 am
Thank you David,
Great news!
Here what i can have from MaxxECU (in the case to use the ADL)
Offset: 0
Scale: 1
Type: int16
Rate: 50hz
But i'm silly, dont know where i can put the infos into the MoTeC Dash Manager....
To much cell to fill, any advice?
Thank You David
Francois
insomnia
Return to ADL, ADL2 and SDL
Users browsing this forum: Bing [Bot] and 9 guests
