CDL3 Fuel Comp
CDL3 Fuel Comp
Postby Carlos Iglesias on Thu Dec 19, 2024 11:43 am
I've setup a CDL3, and I had the Fuel Comp generating data. After a wiring issue due to a faulty AV1 (Fuel Level) connector, the Fuel Comp disappeared. I reloaded the standard templates with no-joy. How do I pull Fuel Comp back into a template?
Cheers, Carlos
Carlos Iglesias
Re: CDL3 Fuel Comp
Postby David Ferguson on Thu Dec 19, 2024 12:13 pm
Do you mean Fuel COMPensation, or Fuel COMPosition (Alcohol percentage). What ECU are you connected to? What templates were you using?
Can you share your CDL3 Configuration?
Re: CDL3 Fuel Comp
Postby Carlos Iglesias on Thu Dec 19, 2024 8:48 pm
Thanks for the lickety-split response, David. Mea culpa for the short explanation. I meant Fuel Composition (E%).
My rig is an M130, CDL3 (vers. 160Z), LTC, and a Keypad. CDL3's Setup:
Comunications
M1_General_0x640
M1_General_0x650
M1_General_0x670_Version 1
LTC #1 (CAN ID 460)
Keypad Button Rx - Fixed
Devices"
AV1 Fuel Level (received Channel disabled)
AV2 Low Fuel Switch
AV3 Ang OilPressure Low Switch
AV4 Air Press ICooler
AT1 <blank>
AT2 AIr Tmep Icooler In
DIG1 Display Next
DIG2 Alarm Ackn
SPD1 MDD Backlight Volt
SPD2 <blank>
SPD3 <blank>
Carlos Iglesias
Re: CDL3 Fuel Comp
Postby David Ferguson on Fri Dec 20, 2024 10:06 am
"Fuel Composition" is found in the CAN template M1_General_0x670_Version 1
You might want to check that the channel is "ticked" to be available in the CDL3. Monitor Channels in the Dash Manager would help. If the value received is correct, then look at your display, or check to see where else that channel is used. If the value isn't being received from the M1 -- then I would use M1 Tune to make sure there is no sensor fault, and see if it reads the value correctly with M1 Tune connected.
Re: CDL3 Fuel Comp
Postby Carlos Iglesias on Sat Dec 21, 2024 12:57 pm
"Murphy" isn't going to give it up easy on this one... giving me the big FU !!
All of the M1_General_0x670_Version 1 Received Channela indicate "Channel Not Found"
I tried to edit the Channels, but again, I couldn't find hide-nor-hare of Fuel Composition (FC) frrd from the M1.
FC does not show up in [url]Monitor[/url]. I have no other communication issues.
The M130 displays the Fuel Composition sensor, calibration, resource, settings, and reading without warnings or errors.
The most annoying part about this is that it was displaying correctly in the CDL just a week ago. To the best of my recollection, I've backtracked all the steps I took since then... with no joy. Hope the old salts of this group can help!
Carlos Iglesias
Re: CDL3 Fuel Comp
Postby David Ferguson on Sun Dec 22, 2024 8:58 am
Install one of the newer dash managers (like C125 Dash Manager), this will update the global channel list.
Re: CDL3 Fuel Comp
Postby Carlos Iglesias on Sun Dec 22, 2024 9:01 pm
Merry Christmas, Mr Ferguson... and thank you for the early Christmas gift. All M1_General_0x670_Version channels received.
Cheers, Carlos
Carlos Iglesias
Return to ADL3, SDL3 and CDL3
Users browsing this forum: Majestic-12 [Bot] and 6 guests
