Cooling fan wont start. newbie alert!
Re: Cooling fan wont start. newbie alert!
Postby Stephen Dean on Tue Oct 15, 2024 9:21 am
Try this one.
GPA (M130) [01.11.0159, July 2019] Widebody Swift v2.0 , MoTeC 10_09_24 (1).m1pkg-archive
(2.15 MiB) Downloaded 144 times
Postby justineurope on Tue Oct 15, 2024 9:29 pm
Hi Stephen, unfortunately no changes. I erased old packages, imported the new one, sent it not merged it and fan does not come on still.
Any other thoughts.
JP
justineurope
Postby Stephen Dean on Wed Oct 16, 2024 9:24 am
I'm not sure why that didn't work, as it is settings that I have used on numerous other vehicles. Your going to have to work backwards through the activates to see if there is something that is stopping it from turning on.
Where are you located?
Postby justineurope on Wed Oct 16, 2024 2:39 pm
Hi Stephen I'm in Adelaide.
When you say work backwards through the activates...what do you mean?
Thanks for the help
JP
justineurope
Postby Sean on Wed Oct 16, 2024 4:12 pm
Stephen, is there a chance it's to do with having no wheel speed sensor resources defined, so the enable vehicle speed condition isn't seeing any value? Or more broadly, something not right in the speed estimate settings?
Sean
Postby Stephen Dean on Fri Oct 18, 2024 5:34 pm
I have used those settings on vehicles without wheelspeed sensors, so that shouldn't make a difference.
What i mean by working back through the activates is that you need to have certain conditions met to have the final Cooling Fan output to turn on, have a look to see if these conditions are being met, and if they aren't work through the to see why.
Previous
Users browsing this forum: Bing [Bot] and 17 guests
