Engine speed fault
Re: Engine speed fault
Postby David Ferguson on Wed Oct 09, 2024 5:25 am
Those input captures show the signal should be falling edge. It looks like you could use a hysteresis of 2V at 1000 RPM, and probably 7V at 6000 RPM and above.
Thank you for posting those.
Postby Juan on Wed Oct 09, 2024 8:24 am
David Ferguson wrote:It looks like you could use a hysteresis of 2V at 1000 RPM, and probably 7V at 6000 RPM and above.
I will try this setting.
What about debounce?
I have not seen hysteries or threshold noise.
Juan
Postby David Ferguson on Wed Oct 09, 2024 8:46 am
The signal looks pretty clean, for a 60 tooth trigger wheel, I might start with debounce values of (80@0rpm, 60@1000rpm, 15@6000 rpm, 10@10000). Then I adjust as recommended in the help for Engine Speed Pin Debounce.
Postby Juan on Thu Oct 10, 2024 1:39 am
David Ferguson wrote:The signal looks pretty clean, for a 60 tooth trigger wheel, I might start with debounce values of (80@0rpm, 60@1000rpm, 15@6000 rpm, 10@10000). Then I adjust as recommended in the help for Engine Speed Pin Debounce.
Thank you David
Juan
Previous
Users browsing this forum: Google [Bot] and 0 guests
