Need some help if possible.
Have a 4 cyl engine with 12 tooth crank wheel with hall effect sensor. Magnetic sensor on chain driven camshaft.
When I run engine on cars original ecu using a timing light the wheel appears stationary (as you would expect)
But when i connect up the M4 unit and use it to power a coil off the car using a timing light again the wheel seems to wander all over the place.
Have used a scope and have put the trigger point of sync sensor between two fall edges of ref.
The wave forms on the scope appear clean with little distortion.
Any ideas?
In the Main setup have:
no: cyls=4
ref sensor=1 hall
sync sensor=mag
ref/sync mode 14 (fall fall)
ref teeth=12
tooth ratio=50 (although help says not needed)
crip=120
ign type=fall trigger
no coils=1
Thanks in advance.
