FaultCode: Logger config does not match display config
Postby ChrisAkkodis on Thu Aug 22, 2024 6:50 pm
Good morning Guys,
I need your help, please. I've got a problem that I can not solve. It is the Fault Code: "Logger config does not match display config"
But first of all back to the roots:
I made my own DBC File: "Vehicle_CAN_V2", imported that in the Dash Manager and created out of that the DBC File "Dash Manager DBC File Creation" and with that I builded up my Display Creation "DBC in DASH Creation". You could find all the Files attached on this post.
Could you please give me an advice what I did wrong?
Thank you very much in before.
Your Mate, Chris
Dash Manager DBC File Creation.dbc
(9.71 KiB) Downloaded 331 times
DBC in DASH Creation.dcproj
(404.12 KiB) Downloaded 328 times
VEHICLE_CAN_V2.dbc
"Vehicle_CAN_V2"
(40.01 KiB) Downloaded 349 times
ChrisAkkodis
Re: FaultCode: Logger config does not match display config
Postby SOReilly on Fri Aug 23, 2024 12:50 pm
Hi Chris,
Have you checked out the webinar on this?
https://www.youtube.com/watch?v=GwllFYmbyew
SOReilly
Postby Stephen Dean on Fri Aug 23, 2024 12:53 pm
Hi Chris,
As suggested by Scott, check out the webinar.
What is happening is that you have a mismatch between the Dash Manager Configuration and the Display Creator configuration. Display Creator is expecting that the Dash will be transmitting a setup of channels that matches the configuration in the dbc that Display creator uses (the dbc the Display Creator typically uses is generated by Dash Manager) but this isn't the case in your setup.
Postby ChrisAkkodis on Fri Aug 23, 2024 7:08 pm
Hey SOReilly,
thank you very much for the fast reply. Yes, I already know that Webinar Video, it is great and helps me a lot.
Best regards, Chris
ChrisAkkodis
Postby ChrisAkkodis on Fri Aug 23, 2024 7:21 pm
Hey Stephen,
thank you very much for the fast reply. I fixed the problem, I forgot to send the created Dash Manager Configuration. Careless mistake from me, I am sorry guys for wasting your time.
You all doing a great job!
Have a nice one!
Best regards, Chris
Screenshot
Dash Manager - send configuration.PNG (386.62 KiB) Viewed 8163 times
ChrisAkkodis
Return to Display Creator
Users browsing this forum: No registered users and 27 guests
